View TCP Global Information
Perform this procedure to view information about the handshake (SYN) configuration and the maximum number of TCP connections you can create on your system. When you initiate a TCP connection, both end points send handshake information to create the channel. The retransmission algorithm and fields display the configured timeout value and minimum and maximum retransmission times that your system uses to terminate a connection attempt that falls outside your specified parameters.
  1. In the navigation pane, expand Configuration > IP.
  2. Select TCP/UDP.
  3. Select the TCP Globals tab.
TCP Global Field Descriptions
Use the data in the following table to use the TCP Global tab.
Name
Description
RtoAlgorithm
Determines the timeout value used for retransmitting unacknowledged octets.
RtoMin
Displays the minimum time (in milliseconds) permitted by a TCP implementation for the retransmission timeout.
RtoMax
Displays the maximum time (in milliseconds) permitted by a TCP implementation for the retransmission timeout.
MaxConn
Displays the maximum connections for the device.
